Old 02-01-2011   #11
kbondra
Default Re: EZ-Clutch Pedal Extension
Originally Posted by FU2 View Post
Pardon , but why would we need this
Some Corvette owners really like it, I guess it caters to the under 5'10" crowd.
kbondra is offline   Reply With Quote
Old 02-04-2011   #12
On Bill's site in the Technical Information section I think he says that it is a must with our zf's that you hit the floor with the clutch pedal. Here's the link.
http://zfdoc.com/techinfo.htm
If I get any more spinal compression ( nice way of saying I'm short & getting shorter I think! ) I'm going to need to make a block for my clutch pedal......these cars were not meant for people under 5' 7"
Old 02-04-2011   #13
kbondra
Good article, notice the Warning:
Warning - Shallow clutching is deadly to these transmissions when powershifting.
This is why I made the Clutch Pedal Extension.
Old 02-04-2011   #14
Looking at the design, and the way our Clutch pedals are I don't think it will work without modifying you add on part, let alone drilling our pedal
As for me, I am 6'5" and have no problems depressing the clutch pedal into the engine compartment
Old 02-06-2011   #15
kbondra
This is made for the 5'9" and under crowd. At 6'5" you are probably looking for even more legroom.
Yes, the four holes would have to be drilled through the ZR-1 clutch pedal but it will fit on the pedal nicely.
Old 02-07-2011   #16
scholtmj
scholtmj's Avatar
Have you actually installed one in a C4?
scholtmj is offline   Reply With Quote
Old 02-07-2011   #17
kbondra
No. Have put it on other vehicles though. Will have to try it out.
