Old 09-10-2010   #31
Polo-1
Default Re: Smokey and the bandit
My suggestion..
build spare motor.. buy Dom's heads..
done...
I will have a 380ci Mini Stroker short block for sale soon.
Old 09-10-2010   #32
I Thought we agreed to a straight up trade for that crank locator tool on the stroker block, No?
LGAFF is online now   Reply With Quote
Old 09-10-2010   #33
Old 09-10-2010   #34
Well, I got out the "Junk" heads and they are not that bad..."
Thoughts?
Where have I heard words like that uttered before? I guess this time it's north of I-80.
Old 09-10-2010   #35
So what happens when you pull it out, swap heads, button it up and it still smokes since you are leaving the bottom end alone?
i still say, build the spare block..
Old 09-10-2010   #36
No holes, not warped, if I recall the valve guides are new...so a clean up and check them over, should be good to go.
Old 09-10-2010   #37
No I am going through the block.....I will use the existing one in the car as the pistons and liners and in good shape.
Old 09-10-2010   #38
you had it apart to look already?
Old 09-10-2010   #39
No, if you recall the one from #702 ate a screw and chipped some of the liners and pistons....as the liners generally do not wear, I am assuming they are in better shape in #966.
Old 09-10-2010   #40
Ah yes I remember now. I just figured while it was out you would take a look at the rotating assembly.
so when is the heart surgery starting?
