#11 | |
![]() Join Date: Aug 2006
I recall seeing a thread discussing merits and demerits between Dewitt and Fluidyne radiators. If I remember (I may have this backwards) correct, Fluidyne seemed to be the better choice for street use. I replaced mine with factory radiator that came out of a 95 with a few thousand miles from a forum member. He was extremely generous and let me have it for $50 (you know who you are...Thanks!). Cooling has not been a issue ever since. Also, I thought about intake screen but when I pulled the old rad, it was obvious that it wasn't just small debris but amount of fine particles that came out between fins were quite a bit. I can't see any type of screen that could allow air and yet keep fine particulate from collecting between rad fins. |
#12 | |
![]() Join Date: Jul 2005
I have to agree about the HD radiator. When I did mine I put an OEM back in and no problems. Also regarding the screen, I did that when I had my radiator out. You wouldn't believe how small of particals that it stops from going up into your radiator. Even if you are not mechanically inclined this can be done with very little effort and most of the tools you would have laying around your house. Try it - you won't be disappointed ![]() Good luck and save some money with the OEM radiator ![]() ![]() ![]() |
#13 | |
Correct sand, dirt and slit wont be blocked, but the major debries like leaves, bags, straws and everything else will.
#14 |
#15 | |
#16 |
#17 |
You do know that a HC radiator is not a drop in...? Mods to the mounts will be required because they are thicker.
H ![]() |
#18 |
![]() Join Date: Dec 2004
On the particulates......this is just a fwiw.
When I made my screen, I wrapped the rigid screen in regular fiberglass screen ( the replacement stuff on the roll ). I did a lousey job in that the fine screen material ended up having alot of folds in it on both sideas of the rigid stuff. Ya know I do find a good bit of dirt particles in it when I clean out the leafs & junk. ![]() ![]() Tom
#19 | |
Another idea the old sand rail dune buggy crowd was to place panty hose (Nylons) over their air filters to keep the fine sand and grit out. Military used this in DS/DS in th 90s as well.
#20 |
Just replaced my high performance radiator with a stock unit. What a difference! Temperature stays nice and cool when driving around town. Before, thirty seconds after getting off the freeway the needle would be bumping the max temperature line.
I did a nice test drive just long enough for the gas guage to break. Now it reads empty all the time. Probably the sending unit. Oh well, as I said before, as soon as I fix one thing, something else goes wrong. |
