Old 02-11-2009   #1
White Bullet
White Bullet's Avatar
Default Engine Power Key/Switch 1991
I have done some searching and can not find what I am looking for or the answer is there a I missed it. Anyway I have a need to replace the radio bezel. I need to modify it to allow for a stereo installation and do not want to use the one in the car. So I am considering purchasing a reproduction bezel to modify it but this leaves the power key out. Here are my options:
1. Replace the prom.
2. Replace the key switch with a momentary contact switch?
3. Relocate the key switch to another accessible location. Any suggestions as to where? It is fairly large.
Questions?
1. Replacing the prom would I still need the switch connected? This seems to be kinda of a stupid question but you never know.
2. Using a momentary switch what rating should it be?
At this time I have been unable to find another radio bezel for the ZR1 which could be used to be modified.
White Bullet is offline   Reply With Quote
Old 02-11-2009   #2
Default Re: Engine Power Key/Switch 1991
Just buy a stock Bezel for your car and modify it. The fits the same minus the key and module. Jeffvette did this and also added his Valentine radar detector hidden display module to the lower left of the bezel and he moved his key over to the middle right of the bezel. ask him for a picture it will give you a pretty good idea of what to do. It was a very clean install.
Old 02-12-2009   #3
White Bullet
Thanks. I will.
Old 02-12-2009   #4
Jeffvette
Darryl, the 90 key cylinder is completely different from the 91+.
Old 02-12-2009   #5
White Bullet
Jeff,
That looks sweet .
Old 02-12-2009   #6
Yes I know no module (91-95 only) but it can still be moved over I beleive.
Old 02-12-2009   #7
Jeffvette
The mounts are molded into the bezel. A base bezel has no provision for mounting.
Old 02-12-2009   #8
Unless its epoxied to the new postion. I know I know But it can be done lol. Which is why I suggested a stock bezel who cares if its high temp RTVed or Epoxided to the back of a stocker unit???
But Jeffvette is right behind the stock ZR-1 91-95 bezel is indeed mounts to secure into.
Old 02-23-2009   #9
White Bullet
Thanks for everyone's help. Here is the reproduction bezel installed with the key. Not perfect but it works.
