Old 10-29-2022   #1
Jetjock
Jetjock's Avatar
Default Removing knock sensor connector
I'm having a heck of time removing the knock sensor connector off the knock sensor. I can get my hands on it but won't come off. Is there a trick to it or I just have to pull harder?
Roy
Roy L. Carman
If I feel the need for speed,
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
Old 10-29-2022   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Removing knock sensor connector
Squeeze together the narrow section of the outer plastic shell and it will release
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 10-30-2022   #3
Roy
Roy love that side by side thumbnail.
Old 10-30-2022   #4
Jetjock
Jetjock's Avatar
I got the old knock sensor out but I can't get the new one to start. I don't have a lift so I jacked up the side of the car as far as I can. I'm having to use the 7/8 socket to install it and the extension is pretty heavy due to the larger size extension and it's wearing me out because of the damage to the my left shoulder. I'll keep doing it but this is going to take a while.
Roy
Roy L. Carman
NCM Lifetime #1468
Old 11-01-2022   #5
Jetjock
Jetjock's Avatar
I like this one much better!
Roy L. Carman
NCM Lifetime #1468
Old 11-01-2022   #6
If I remember correct, manual calls for 14 ft-lbs. Please check the manual and verify torque spec. Inaccurate torque and readings to ECM may not be correct.
Old 11-01-2022   #7
Jetjock
Jetjock's Avatar
I'll do that after I get it installed which is the primary problem at the moment.
Roy
Roy L. Carman
NCM Lifetime #1468
Old 11-02-2022   #8
Jetjock
Jetjock's Avatar
I got the knock sensor in but it got real hard to tighten up and took it out. It went only part way up. So I looked at the old one and it shows that it was only part way also. I guess the question is this: are they only supposed to go part way up and or was the threads stripped somehow?
Roy
Roy L. Carman
NCM Lifetime #1468
Old 11-03-2022   #9
Jetjock
Jetjock's Avatar
Well, learned something new today. Apparently, you don't run the knock sensor all the way up to the engine. It only goes in so far and stops. I had it in right and I removed it because I thought that I was cross threading it. Now I'm having issues putting it back in. At least, it's in my garage, I'm retired and I can work on it on my leisure.
Roy
Roy L. Carman
NCM Lifetime #1468
Old 11-03-2022   #10
Roy
Once you hand tighten and a bit more with a ratchet, finish off with 14 lb ft.
