-   -   Removing knock sensor connector (http://zr1.net/forum/showthread.php?t=34439)
Jetjock 10-29-2022 03:27 PM
I'm having a heck of time removing the knock sensor connector off the knock sensor. I can get my hands on it but won't come off. Is there a trick to it or I just have to pull harder?
Roy
Jagdpanzer 10-29-2022 07:08 PM
Re: Removing knock sensor connector
Squeeze together the narrow section of the outer plastic shell and it will release
GOLDCYLON 10-30-2022 04:45 PM
Roy
Roy love that side by side thumbnail. :cheers:
Jetjock 10-30-2022 04:50 PM
I got the old knock sensor out but I can't get the new one to start. I don't have a lift so I jacked up the side of the car as far as I can. I'm having to use the 7/8 socket to install it and the extension is pretty heavy due to the larger size extension and it's wearing me out because of the damage to the my left shoulder. I'll keep doing it but this is going to take a while.
Roy
Jetjock 11-01-2022 10:58 AM
1 Attachment(s)
I like this one much better!
secondchance 11-01-2022 03:47 PM
If I remember correct, manual calls for 14 ft-lbs. Please check the manual and verify torque spec. Inaccurate torque and readings to ECM may not be correct.
Jetjock 11-01-2022 06:45 PM
I'll do that after I get it installed which is the primary problem at the moment.
Roy
Jetjock 11-02-2022 10:56 PM
1 Attachment(s)
I got the knock sensor in but it got real hard to tighten up and took it out. It went only part way up. So I looked at the old one and it shows that it was only part way also. I guess the question is this: are they only supposed to go part way up and or was the threads stripped somehow?
Roy
Jetjock 11-03-2022 09:36 PM
Well, learned something new today. Apparently, you don't run the knock sensor all the way up to the engine. It only goes in so far and stops. I had it in right and I removed it because I thought that I was cross threading it. Now I'm having issues putting it back in. At least, it's in my garage, I'm retired and I can work on it on my leisure.
Roy
secondchance 11-03-2022 10:19 PM
Roy
Once you hand tighten and a bit more with a ratchet, finish off with 14 lb ft.
