#21 | |
![]() Join Date: May 2010
I think you should be all set with just the 5000TL, but I might not be the best person to ask because I have the no-flex bars on my car with easy pick up points. I?m not sure how a stock car is lifted as far as pick up points with the QuickJack. I see they have new accessories like the pinch weld pucks. I used similar to lift my car with a floor floor Jack before I had my no flex bars added. Sent from my iPhone using ZR-1 Net Registry
#22 |
![]() ![]() Join Date: Jul 2016
I just ordered a 5000TL after watching this guy use one for his C4...
https://www.youtube.com/watch?v=vvCQQyt1L-U |
#23 |
I've got a low profile floor jack and made an aluminum pad that comes in contact with the car. I use the pinch welds at the front/back of the car and have never had any issues raising the car.
#24 |
Too bad the jack-a-vette and EZ Jack adapters are no longer produced. They make jacking up the back of the C4 vette a snap.
#25 |
![]() Join Date: Nov 2016
These do the trick as well. Please ignore the semi-finished garage. The left pallet contains the tiles, and the right ones has the workbenches/cabinets.20220423_211757.jpg
Sent from my SM-F926B using ZR-1 Net Registry mobile app
- '90 ZR-1 |
#26 |
Is that bolted to the floor? Even so, I would really worry about that getting knocked over and falling to the floor.
#27 |
It is indeed. Approved for approx 7700lbs, and sits flush with the floor when fully lowered. Lifts almost 6 ft.
- '90 ZR-1 Last edited by S.hafsmo; 05-27-2022 at 03:42 AM. |
#28 | |
#29 |
![]() Join Date: Sep 2016
I just ordered an open box QJ 5,000 not the TL for $950. I think I scored. Been looking a while. V2V does make it more difficult with a floor jack. Put that baby on the QJ and no more bending over. I need to conserve my joint jelly for 20 more years or more!
#30 |
You are going to love them. I do my oil changes w them and they make swapping out O2 sensors pretty simple.
