Old 01-25-2021   #11
Default Re: Help with some problems with my 92
Originally Posted by WARP TEN View Post
Question: Does your car have catalytic converters or have they been removed for headers? It looks like your exhaust is stock from the video but I also had a stock system from headers back on my '95 but removed cats to go with headers. I also regularly had a bad smell on startup but that was the old smell of the '50s and '60s--before cats, when we tuned cars by smell and the look of the smoke out the exhaust. If your car does have cats, is it possible they have become non-functional? If your cats are fine and you think you have an exhaust leak it would have to be ahead of the cats to produce the smell you describe, I would think, which would mean headers. Certainly an exhaust leak should be corrected. Also, my take on the "smoke" and moisture from the mufflers is that it is simply condensation and entirely normal. I also had it. The pipes are lower than the muffler outlets for much of their length and a lot of moisture can accumulate in them. Drive for an hour or so then see if you get much on a cold start afterwards. As to a clunk in the suspension somewhere, I also had such a clunk especially when I backed out of my slightly inclined driveway, afterwards normally I wouldn't notice it. While everything looked fine, Marc changed the sway bar bushings and that solved it--no more clunk. My car had only 30k miles on it but the bushings just got old and hard. You indicated you felt it in the steering wheel so maybe front bushings need a look. --Bob
Still has catalytic converters and the exhaust is stock. I'll have to inspect more in front of them.
I hear you on the smoke and condensation, but fortunately, I have my 91 to compare to and in the same conditions, it produces no noticeable smoke or condensation, whereas the 92 is VERY noticeable.
Clunk/click only happens going back and forth. Just based on their age, I'm planning to replace the bushings when I can.
Thanks for your thoughts!
Old 01-25-2021   #12
Issue #2:
If clunking noise is when you go over left to right uneven road (car swaying left to right), I would suspect worn out rear sway bar bushing. I recommend urethane bushing since OEM rubber bushing will fail quite fast.
If clunking noise is from directional change as in forward, stop, reverse, most likely driver side rear bearing hub being torqued to 160 lb-ft. This was revised to 190 lb-ft by Chevrolet.
Only happens back and forth. Yes, will use urethane bushings! I'll check out the torque spec
Old 01-25-2021   #13
The black, sooty condensation from the exhaust at first startup of the day is symptomatic with leaking injector housing gaskets at the cylinder head interface. Coolant seeps into adjacent intake port, accumulates & blows out on first cold start of the day.
This sounds like a significant effort and I'm certain would be beyond my knowledge/experience to tackle.
I've been thinking about sending the car to Haibeck for an overhaul and engine refinishing, but I want to gather much more information before I commit to that kind of time and expense.
I've only done limited research on Marc's services so far...I'm assuming the housing and gaskets would be inspected/replaced if necessary?
Thanks for the valuable info,
Old 01-25-2021   #14
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
1- pull the plugs
2- look at the plugs
3- one or more will be black
4- replace the plugs
5- ONLY AFTER you replace the Injectors
With as much carbon and soot you are showing, it looks like your injectors are dumping fuel. Likely failed due to alcohol as they are pre 93.
Your ZR-1 requires basic maintenance including plugs and injectors. It is 28 years old.
I would also agree with an earlier poster that you also likely have leaks at the injector housings, but start with the simple stuff, if injector replacement resolves the issue, stop there. If not; then have a round two.
Marty
Old 01-25-2021   #15
wfot
wfot's Avatar
I have a set of injectors up for sale currently, they are accel 21 lb injectors that already have the secondary nub filed done, so they are ready to install with all O-rings -
the injectors are a number one issue with the 90 - 92s.
https://www.zr1.net/forum/showthread.php?t=32652
Just an FYI
wfot is offline   Reply With Quote
Old 01-25-2021   #16
Originally Posted by DRM500RUBYZR-1 View Post
1- pull the plugs
Marty
Will follow this advice. Here's a pic of one of the plugs...we pulled 2-3 and they all looked like this one, or worse.
Old 01-25-2021   #17
Just an FYI
Let me do more research on injectors and what's involved, then I'll get back to you...thanks for letting me know!
Old 01-25-2021   #18
wfot
wfot's Avatar
Old 01-25-2021   #19
BTW, the LT-5 does not use a Mass Air Flow sensor. It is a Speed Density motor w a MAP sensor.
Old 01-26-2021   #20
Young1
Young1's Avatar
Jkruz, I can take care of your under plenum needs. Send me a PM with your contact info and we can talk.
Steve Young
Second Owner
SOLD
SOLD
