View Poll Results: Have you ever hit the rev limiter? | |||
YES | 147 | 67.12% | |
NO | 72 | 32.88% | |
Voters: 219. You may not vote on this poll |
Thread Tools | Display Modes |
11-05-2020 | #141 |
Re: Poll: Who has ever hit the rev limiter?
Haven't hit it nor do I know what it is set at.
Only purchased the car a few weeks ago. 368ci Corey Henderson built 1991 Z. 4.10 gears. I did 3 pulls in second gear and the tach needle swept just above 8000 each time at which point I decided I better shift. Don't know if it is accurate but sure sounds like it's well north of 7000 anyway. |
11-05-2020 | #142 |
Technically not stroked. It's one of Pete's 391 cubic inch closed deck blocks (larger bores) with stock crank. Add to that Pete's port work of everything and his aggressive stage 2 cams (plus of course long tubes, no cats and Corsa exhaust). Makes peak power at 6500rpm and holds it all the way to redline. Build thread here.
Evan
2023 70th C8 HTC, 94 Admiral Blue ZR-1 SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP SOLD - Steel Blue 91 391cid ZR-1 #391 SOLD - Black 91 ZR-1 |
11-05-2020 | #143 | |
Evan
11-05-2020 | #144 | |
Was your tach off a consistent percentage throughout the range or was it only skewed at the top? |
11-05-2020 | #145 |
It's been several years, but I think it was skewed more at the top end (pretty sure I would have remembered it being off by 1K or more at idle).
Evan
11-06-2020 | #146 | |
Here is a chart you might use to see if your tach is tracking correctly...assuming your speedo is corrected for the 410 gear! And...(IIRC) there is a way to determine the RPM from the DIC (digital information center - the display in the dash). As I seem to recall, (someone please chime in here!) a number can be retrieved and a multiplier is used to ascertain the actual RPM. OR, if you have a scanner, of course you can read and compare the analog tach to the digital reading. P.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 11-06-2020 at 06:43 AM. Reason: tpyo |
11-14-2020 | #147 |
I checked the tach gauge vs the readout on the HVAC control. Hold up and down fan speed buttons simultaneously until 00 appears then tap up until 06. Tap the fan button. This gives you rpm/25. It won't read all the way to 7000 but I was able to verify my tach gauge reads about 15% high throughout the entire range. So 8000 is really only about 7000. Will have to get it calibrated.
11-14-2020 | #148 |
I don't feel like reading the whole thread, but I'm wondering... I feel like I drive the car really hard... But I don't recall hitting the rev limiter! What happens when you hit it, RPM decreases a little bit by itself, then increases back up?
My 1993 had a steady rev limiter, RPM doesn't decrease when I hit it...
Mazda RX-7 1992 Chevrolet Corvette ZR-1 1991 Dodge Viper RT/10 1994 Mercedes-Benz C63 AMG 2009 |
11-15-2020 | #149 | |
11-17-2020 | #150 |
The power doesnt drop off in a stock LT5 before redline.
Unless you go past the power peak, you will be way below it after your shift. Sent from my iPhone using ZR-1 Net Registry
"It's about the car, not the people." 1991 ZR-1 White/Black #1236 (Owner since 1994). Stock engine with bolt-ons: Hurst shifter,"Forced Air" intake, Coplon duct, Bee Cool Radiator, Demon coils, Jeal prom, Watson headers, X pipe, 3" B&B's, Rippie flywheel, 4:10 gears, A molds, Toyo Proxes-R888's 12.06@117mph. 1.76 60ft. |
