![]() Join Date: Nov 2010
A few months ago I had a head gasket fail on my 91 Steel Blue that I bought end of last year update: turns out it was way worse.
At some point in its life a hose clamp had been dropped in the intake. It apparently sat there for years and then one day, the wife says she hasn't ridden in my new Corvette. So I back it out of the garage (starts fine), she gets in and shuts the door and it suddenly stumbles and start running really rough (not that I'm saying this is all her fault ![]() ![]() I know, how the heck do I go from needing a head gasket to building a 391?!?! Well, it all starts with the little statement of "while you're in there...". ![]() ![]() Pete will also be doing a little other work for me at the same time: installing OBX long tubes, DRM coilovers and a few other little odds and ends. Should make for an absolute beast of a car once it's done! Last edited by EvanZR1; 11-05-2020 at 12:19 PM. |
![]() Join Date: Jan 2006
Nicely done! You'll love it.
Balance ride height with clearance v stance & put urethane bushings on lower rear shocks (at a minimum). Ted |
![]() Join Date: Apr 2017
Sounds like a real Beast!
Can you keep us updated on progress and rough costs? I know that many of us would be interested. Do you know what caused the head gasket problem?
[SIGPIC][/SIGPIC] 91-#1935 Black/black & gray, Haibeck 500 Cams by Pete |
![]() Join Date: Mar 2015
Sounds like a cool plan
Sent from my SM-G930F using Tapatalk |
![]() Join Date: Nov 2007
Wuz hopin' to do that very thing last winter. BUT! Mr. tax man and a wedding teamed up to put it on hold for another season.
DO let us know how you like it! ![]() |
![]() Join Date: Nov 2011
What does it take to turn a 350 into a 391?
What is the expected hp? |
![]() Join Date: May 2010
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
Don't know for sure what caused the head gasket failure. Car has 100K miles on it, but it did sit with very few miles put on it for a significant amount of time (5+ years). I drove the car back from Baltimore to Dallas with no issues, but only a few times since getting it home. While I don't abuse my cars, I do drive them fully (all the way to rev limit) and had taken her for a cruise the weekend before the gasket failed and ran her pretty hard. Gasket failed the next weekend about a minute after starting her up (white smoke, low coolant warning, knock sound).
As for questions of what it takes to do a 391 (and cost), best to contact Pete. He has a post here about 391 build. I will say that the cost of a 391 from Pete is way less than any other quoted numbers I've seen. Expected power for 391 is 575-600HP (including full porting), plus another 25HP for cams. I may go a little more aggressive with cams, so we'll see how it ends up. Would be awesome if we could hit 540RWHP, which is about what stock C6 ZR1s do, but we'll just have to see what she actually does. |
#9 |
![]() Join Date: Feb 2012
#10 |
