#11 | |
![]() Join Date: Nov 2007
I will hopefully be meeting with some of the IL "Z" nuts for a get together tonight. I will be very interested to discuss the possibility of deleting the secondary throttle plates, the actuators, and the 4 relays which have to work in perfect unison to prevent a sometimes stumble with there is a lack of perfect coordination in transition. A chip change may also be needed, but according to Pete, it is a "no brainer", with no practical downside, and possibly a 5 hp gain...WooHoo! Although in down state IL there is currently no requirement for emmissions compliance testing (in Kankakee co), I want to move back to CO one day (sooner the better), or compliance testing might be expanded to my county one day. So, at the very least, I would have to hang onto the "stuff" in case I have to reinstall it for compliance reasons. ![]() So...Like I said, I'm all ears on your project! P. |
#12 | |
So far, with the help of the members here, the project has gone smoothly. Putting parts back in was a snap! It looks like a rats nest when you first pull it all apart, but once you get familiar with each piece, its not too big a deal. I probably only have an hour left of work once I get the actuator. Where in Colorado did you live? We have no emission testing from Colorado Springs south. |
#13 | |
![]() Join Date: Jul 2007
#14 |
I don't understand, so you all are saying you leave the spray-end o-ring on the injector? It won't be held in by anything except the o-ring's tension. I'd be afraid one day it might fall off and get sucked into the engine.
I used '93+ injectors and here is what I did to them prior to installing: ![]() |
#15 |
Aurora, that was my reasoning as well. Thats why I questioned it. I might take them off too, its just my luck & one will fall off.
#16 |
The 1990 primary injector has an "O" ring that sits inside the housing body. The "O" ring fits around the injector body providing the seal. These are about the size of a quarter and no longer available at GM. If you need some let me know I can tell you where to buy them, cost is about a dollar each. These are made of Viton material, same as the original. GM price on these was $25.00 each.
