Accel & Multec Injector ???
Got all my parts in today (thanks Jeff) & see theres a difference in the factory injectors & the Accels. The primaries on the Multecs dont have an O ring on the tips & look different from the secondaries which DO have an O ring.
The Accels look exactly the same & both have O rings. Do I remove the O rings or leave them on (primary side of course)? |
Re: Accel & Multec Injector ???
Well, I don't know if it was right or not, but the Accels I put in, I just put them in. O-rings and all.
Now somebody's going to tell me I have to take it back apart. :P KT |
on 92's & up you shouldn't need to do anything concerning O-rings with the Accel's, individual pt. no: 150121 or eight pack no: 150821. you might need to use a razor blade to remove the plastic guide for the injector harness clip. it's just a guide, the harness will still clip in place by using the tabs on the sides. the guide was so the primary & secondary were not swapped.
The part # is 150821 for all 16. 2 8-pack boxes. The original primaries had no O rings, these all have O rings....Jeff already trimmed the tabs for me, so, no problem there.....:icon_scra
Throw them in and forget about it. Make sure the C-clip hits the first indentation making sure the injector gets fully seated.
And yes, your coils were trimmed and numbered, as were the tabs for the injectors. |
how much cost for 16 injectors?
and how much cost for only 8 inj. ?:) |
and how much cost for only 8 inj. ?:) why you didnt change all of the injectors pal? |
Ok, cool beans, thanks Jeff... theyre ready and installed in the fuel rails. I'll put em in the housings as soon as the stupid secondary actuators come in....so far, we have one good one. Stan at Tom Henry is really stepping up to the plate & helping out with this task of finding 2 good ones.
Hadi, I did all 16. Cost around $540. |
