#91 | |
![]() Join Date: Aug 2015
Sent from my XT1585 using ZR-1 Net Registry mobile app |
#92 |
#93 |
Looks like we’re on the opposite side of the same boat. Mine was 364rwhp today but very lean. Doms going to add fuel and I’ll go back. With these mods we should be in the 390’s...
H ![]() |
#94 |
My techs believe I've got another 15-20 hp when I get the WOT fueling dialed in to 12.8-13.1. I was literally spitting raw fuel out the exhaust!
Going to dial back the PE and rerun next week when I've got some time to tune on the Dyno . Sent from my XT1585 using ZR-1 Net Registry mobile app |
#95 |
This was my dyno run w similar mods. I believe I had Magnaflow catback at this point.
#96 |
Loaded 10% and Inertia pass. Inertia useless in my mind, but put it on the chart as well for giggles.. 369 rwhp loaded.. Like Dom's chart, it's impressive to see the engine carry the RWHP all the way to 7000 rpm!
#97 |
Yes this is a lovely characteristic of DOHC motors. They don’t crater after peak power as do “OHV” motors. Power stays flat. That’s a HUGE advantage.
#98 |
![]() Join Date: Jul 2012
What happened to your torque? Was 405 ft. lbs. when it was rich?
'95 ZR-1, aqua/gray, #167 368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP. |
#99 |
#100 |
Have had some time to experiment with fuel and spark on the top end after porting #473. Slowly sneaking up on what the engine likes using an MD1100 dyno. Have eased in another 2-1/2 degrees between 5500 & 6500 @100 KPA. Max knock retard 0.5 degrees. My fuel cutoff is still sitting at 7,042. The torque is slowly rolling off, but HP is still climbing at 7,000. 406 rwhp, 374 rwtq. How far have you guys pushed fuel cutoff with a stock bottom end?[ATTACH]
