Old 10-16-2018   #81
Ccmano
Default Re: Plenum & Injector Housing Porting
Good work. Now on to the Dyno...
H
Old 10-17-2018   #82
gtcollins@maxnet.co.nz
gtcollins@maxnet.co.nz's Avatar
Good to see it going liked the video
Glen
Sent from my SM-G960F using ZR-1 Net Registry mobile app
gtcollins@maxnet.co.nz is offline   Reply With Quote
Old 10-30-2018   #83
jss06c6
First pass on Dyno. 359 rwhp, 405 rwtq. Engine is VERY rich. Could not log this pass as I needed to use my laptop to control the Dyno. Have this resolved now, so will begin WOT tuning to get AFR to 12.8-13.1 range..
https://youtu.be/2JXzs1lDTBk
Sent from my XT1585 using ZR-1 Net Registry mobile app
Old 10-31-2018   #84
Ccmano
The engine is ported and you have headers, if I’m not mistaken your running stock flywheel. What exhaust do you have?
Mine is going to the Dyno later today with Doms latest tune. We can compare notes.
H
Old 10-31-2018   #85
H
Hans,
We didn’t optimize that part of the tune. I’ll be curious to see how it does as is.
Old 10-31-2018   #86
Steve,
Is this SAE?
Old 10-31-2018   #87
Ccmano
Hans,
I going to have them run an AFR probe and measure it.
H
Old 10-31-2018   #88
H
If they’re running it on a dynojet, they can give you a file, not the paper copy and I can take a look at it with the Dynojet reader for analysis. If u could datalog the run also, that would be helpful.
Old 10-31-2018   #89
jss06c6
Steve,
Is this SAE?
This is loaded like Mustang Dyno, not Dynojet. Yes it is SAE smoothing.
Steve
Sent from my QTAIR7 using ZR-1 Net Registry mobile app
Old 10-31-2018   #90
jss06c6
H
Yes to all. I'm running Stainless Works fro headers to exhaust tips. 3" exhaust.
Steve
