Old 12-19-2007   #1
bradslt5
Default where can i get the water tight connectors for ......
the boxes that are bolted to the bottem of the plenum. previous owner or mech must not have known they were there when they pulled off the plenum. they put them back together with black silicone . what i need is the water tight connectors that push into those boxes . help!!!!!!!!!!!!!!!!!!!!!
Old 12-23-2007   #2
Sgreg
Sgreg's Avatar
Default Re: where can i get the water tight connectors for ......
Phrogs maybe.
Sgreg is offline   Reply With Quote
Old 12-24-2007   #3
gbrtng
gbrtng's Avatar
GM or AC Delco dealers should have repair kits. Or maybe NAPA.
Old 01-10-2008   #4
phrogs
phrogs's Avatar
Do you have apicture of what you are refering to so I can be sure of what you need?
jp
JOHNNY P
Currently own
Old 01-11-2008   #5
bradslt5
I dont have any way to post pics ( computor rookie) what i need is the 2connectors for the electrics that are bolted to the bottem of the plenum. guess previos owner didnt know they were there when taking off the plenum
Old 01-11-2008   #6
phrogs
phrogs's Avatar
Ok you have the ignition module bolted to the plenum then you have 2 conectors that plug into the front portion of the module they plug in.
There is a third plug that conects at the back of this module and this one has a bolt that screws into it.
So you need the 2 that are at the front.
I have seen these many times broken due to heat and becoming brittle.
JOHNNY P
Currently own
