-   -   where can i get the water tight connectors for ...... (http://zr1.net/forum/showthread.php?t=4440)
bradslt5 12-19-2007 11:31 AM
the boxes that are bolted to the bottem of the plenum. previous owner or mech must not have known they were there when they pulled off the plenum. they put them back together with black silicone . what i need is the water tight connectors that push into those boxes . help!!!!!!!!!!!!!!!!!!!!!
Sgreg 12-23-2007 05:40 PM
Re: where can i get the water tight connectors for ......
Phrogs maybe.
gbrtng 12-24-2007 01:35 PM
GM or AC Delco dealers should have repair kits. Or maybe NAPA.
phrogs 01-10-2008 10:17 PM
Do you have apicture of what you are refering to so I can be sure of what you need?
jp
bradslt5 01-11-2008 09:49 AM
I dont have any way to post pics ( computor rookie) what i need is the 2connectors for the electrics that are bolted to the bottem of the plenum. guess previos owner didnt know they were there when taking off the plenum
phrogs 01-11-2008 02:52 PM
Ok you have the ignition module bolted to the plenum then you have 2 conectors that plug into the front portion of the module they plug in.
There is a third plug that conects at the back of this module and this one has a bolt that screws into it.
So you need the 2 that are at the front.
I have seen these many times broken due to heat and becoming brittle.
