#1 | |
![]() Join Date: Mar 2014
I like them, easy on your back when trying to line up the wheel holes to the studs. No more using your finger through the wheel hole to feel for the stud, you know when your almost there, but's if off by a hair....and your finger will thank you....... ![]() Plus for the aftermarket wheels and calipers, you have a much better chance of the wheel not tilting and not damaging anything in its way......
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 08-28-2017 at 06:23 PM. |
![]() Join Date: Jan 2010
You could get by with just one of them?
![]() Join Date: Feb 2012
![]() Join Date: Aug 2006
Or even non, if you are continuously turning against the wheel with no lug nuts.
Actually the day I drove home from Jim's after 3 days of installing motor after the first rebuild (yes. My motor was rebuilt twice. Definitely living up to my handle...), I found out the next day that lug nuts on both my front wheels were hand tight. Frank, the mechanic who pulled my motor at his home before being towed to Jim's garage must have removed both wheels for some reason and never tightened them. To think I was running the car at 75-80 on I-70 and I-270 for 80 mile trip... |
No, not really....the way it was explained and it does make sense is that if you only used one lug guide tool, then the weight of the wheel would lean down and possibly damage those nice calipers you have. And also you lose leverage to say the least. With three, it makes it so much easier to "slide" the wheel on and know that it will be lined up perfectly to accept two of the lug nuts with no problem.....I bought 3 as recommended....can't wait to try them out.....
#7 | |
Ya shoulda bought 5! Maybe 20? 😀 |
