Old 07-09-2007   #1
pig_iron
Default Re-wiring the power key
Sorry if this topic has been covered but I have combed the threads and not found anything on it yet. I have the center console apart for stereo reasons and was wondering if anyone knew how to wire the power key so it is always on? I'd rather do it now while everything is apart...
pig_iron is offline   Reply With Quote
Old 07-10-2007   #2
tpepmeie
Default Re: Re-wiring the power key
What year? Best bet is to modify the calibration to startup in Full Power mode.
Old 07-10-2007   #3
pig_iron
1991.
Old 07-10-2007   #4
Most do this with a custom chip---fans on at lower temps---elim of cags 1-4 shift---changes to the performance curve ---and key always on--
all are typical of a mod chip change out---
check out the long running thread on "what chip do you have" for mfg of the various chips and what everyone had to say about them!!!
Old 07-10-2007   #5
zr-1assassin
zr-1assassin's Avatar
i was wondering... what is the way to do this on a 90? i have always heard the chip and the midamerica plug only works on the 91-95. is the only way to direct wire it on a 90?
zr-1assassin is offline   Reply With Quote
Old 07-10-2007   #6
Jeffvette
jump the terminals with a spade
Old 07-10-2007   #7
bobbyhi
bobbyhi's Avatar
I used a paper clip on mine while I was waiting for a new key cylinder.
Old 07-10-2007   #8
zr-1assassin
a spade?
Old 07-11-2007   #9
http://store.nutsandbolts.com/electr...als-vinyl.html <<<< spades click on
never knew u could do a 90 that way-
Old 07-11-2007   #10
jonszr1
jonszr1's Avatar
Iput a nice little rocker switch in instead of the key switch . it stays on all the time
