Old 05-29-2005   #1
pig_iron
Default Running rough...
Lately the Z has been hesitating a tad after shifting gears. Today I went to start it and it sounded like a cat was caught in the engine. It ran a few miles to the storage unit, where it proceeded to run smoothly and then suddenly die. I tried restarting several times with the same result. The Service Engine light is on. Could this be a fuel pump problem?
pig_iron is offline   Reply With Quote
Old 05-30-2005   #2
Z Factor
Z Factor's Avatar
Default
Have you tried running it cold to see of it dies after warming up?
Have you checked your map sensor connection?
Old 05-30-2005   #3
pig_iron
Default
At the risk of sounding like a complete dumbass I'm going to have to ask where the map sensor connection is.
Old 05-30-2005   #4
Z Factor
Z Factor's Avatar
Default
There are no dumb questions since we all had to learn at one time. It is right behind the plenum. There is a small space between the firewall and the plenum and the hose connection is there. Typically it gets blown off, but it can also develop a hole/crack. Just take a flashlight and look from the side to see if it is intact and connected. While it might be something else, this common problem is a quick and easy thing to check.
Old 06-06-2005   #5
pig_iron
Default
The map sensor connection it was. Thanks.
Old 06-06-2005   #6
Z Factor
Z Factor's Avatar
Default
My pleasure, Yoda
