Running rough...
Lately the Z has been hesitating a tad after shifting gears. Today I went to start it and it sounded like a cat was caught in the engine. It ran a few miles to the storage unit, where it proceeded to run smoothly and then suddenly die. I tried restarting several times with the same result. The Service Engine light is on. Could this be a fuel pump problem?
Have you tried running it cold to see of it dies after warming up?
Have you checked your map sensor connection? |
At the risk of sounding like a complete dumbass I'm going to have to ask where the map sensor connection is.
:cheers: |
The map sensor connection it was. Thanks.
