Old 06-29-2012   #1
MikeGolf
Default Ram Dual Disc Clutch vs. Traditional GM clutch
At the Gathering we were itroduced to the Ram Dual Disc Clutch.
http://www.ecklerscorvette.com/corvette-clutch-kit-ram-dual-9-5-disc-lt5-1990-1993.html
I heard several people have already installed these in their cars. My questions are:
1. How does it compare to the traditional GM clutch setup?
2. How was the install?
3. Would you recommend the dual disc or the Ram single disc for a stock engine that is taken to the track from time to time?
4. Streetablity of the Dual disc?
I quess what I'm really saying is for the guru's to give me some pros and cons so that I won't have to be the quinea pig here. I know the company is reputable, the design is sound, I like the hydraulic throw out bearing vs the fork and weight loss, although I really would prefer a manual clutch.
It is JMHO but this type of setup will have to be the way of the future for our cars due to the problems we have in the bellhousing area.
TIA
Jeff
MikeGolf is offline   Reply With Quote
Old 06-30-2012   #2
Bob G
Default Re: Ram Dual Disc Clutch vs. Traditional GM clutch
the single disc will be just fine for a stock lt5 . will also work well with a top end ported 350 .the stock clutch is junk the pull type pressure is not flat so it only rides on about 1/3 of the disc after thousands of miles it will ware in o work so so . the 9.5 dual disc is the best it will probably be the last clutch you will ever buy for the lt5
Bob G is offline   Reply With Quote
Old 06-30-2012   #3
MikeGolf
That was my thinking on look at it. But interested in the installation of the throw out bearing alignment shaft to the transmission?
Old 06-30-2012   #4
I really like my Stage 3 from Carolina Clutch
http://www.carolinaclutch.com/Conten...te-lt.htm.aspx
Plus I went with a alum. Fidanza
http://www.carolinaclutch.com/ShowIt...0Flywheel.aspx
but be ready for the syncro gear rattle since the dual mass is gone.
Old 07-01-2012   #5
Bob G
the bolt is supplied with the bearing all You need to do is drill a 1 inch to a1 1/4 inch hole in the bellhousingat about 4 o clock, there is a nice flat spot there, this allows you to stick a screwdriver in and line up the bearing
Old 07-01-2012   #6
Blue Flame Restorations
Bob, is the ram clutch too stiff at the pedal for comfortable street driving?
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 07-01-2012   #7
Pete
Pete's Avatar
Brett,it's a bit firmer but very precise feel,the stock clutch is way too soft.
I have a dual disc Ram in my Z and just love it,it's the best clutch set up i've ever had.
I'm very happy with it.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 07-01-2012   #8
Pete
Pete, if I don't make it to Chicago by the drag race weekend, maybe I can try yours out (not on the track, LOL)?
Old 07-02-2012   #9
Pete
When did this one come on the market Pete?
How long have you had your in?
Old 07-02-2012   #10
Pete
Pete's Avatar
Bryan,i've had this for about a year,it replaced my old Stage 3 set up, i hated driving the Stage 3 in traffic too grabby, this dual disc holds the power and drives like a stocker.
For the extra little bit of money you get new aluminum flywheel, 2 clutch discs,throw-out bearing and all the hardware needed to finish the job.
Brett,you can test drive anytime you want brotha.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
