Old 07-29-2009   #1
Default ZR-1 Ten Commandments
Feel free to add to the list...should be a sticky
1.Thou shalt not use Dexcool
2. Thou shalt not use hydraulic pressure in attempts remove the pilot bearing...unless thou shall want to feel the wrath of the crank plug leak
Old 07-29-2009   #2
Default Re: ZR-1 Ten Commandments
3. Thou shalt learn to pull plenum and own long stem T-45 torx.
4. Thou shalt run the motor to 7000 rpm at least once a week.
Old 07-29-2009   #3
This one is for Dominic after my 90 almost killed him last week.
5.Thou shalt place a screwdriver in the hood prop, lest thou want to be decapitated by the hand of God....or a strong wind.
Old 07-29-2009   #4
Jeffvette
Thou shalt know it's a T-40.
Old 07-29-2009   #5
Hammer
Hammer's Avatar
Talking Re: ZR-1 Ten Commandments
6. Thou shalt not wash thy motor without assuring the plenum valley drain hole is clear.
Old 07-29-2009   #6
Toyvet1
Thou shall not drive with power key off
Old 07-29-2009   #7
Thou shalt not take thy ZR-1 to a unknowing dealership for engine maintenance, especially not an oil change!
Latest one I know of; dealership "worked" on the engine, severely damaged it & tried to cover up a broken piston by welding the broken piston while still in the cylinder. Then sent it home with the owner....... like it was fixed......NOT!
Old 07-29-2009   #8
http://www.youtube.com/watch?v=4TAtRCJIqnk
Old 07-29-2009   #9
Thou shalt know its T-45 after using a short t-40, stripping it out and moving to the next size in desparation to make it work.
Old 07-29-2009   #10
salvatore1
Thou shall not own a Z unless he has the patience of Gandhi......
salvatore1 is offline   Reply With Quote
