Old 12-07-2005   #1
crazyb1
crazyb1's Avatar
Default Throttle cable clamp
Where can I find a replacement for the throttle cable clamp that holds the cables down across the plenum? Thanks for your help,
crazyb1 is offline   Reply With Quote
Old 12-08-2005   #2
Jeffvette
Default Re: Throttle cable clamp
Should be a dealer item, I'll get you a part number in a hour or two.
Old 12-08-2005   #3
Jeffvette
Discontinued.
But I think I have a source for them.
Old 12-08-2005   #4
crazyb1
crazyb1's Avatar
Thanks. I appreciate your help. I've seen on several Zs that these clamps have been either painted or powdercoated. Which is it?
Old 12-09-2005   #5
phrogs
phrogs's Avatar
Mine are bare steel
JOHNNY P
Currently own
Old 12-09-2005   #6
Jeffvette
They are bare but have the same protective coating on them that the small pipes do for coolant and the PCV system.
Old 12-10-2005   #7
FASTZR1
I also need one of these clamps, as well as the small torx screw that holds it in place. Let me know when you find one!
Thanks,
JohnnyB
FASTZR1 is offline   Reply With Quote
Old 03-24-2006   #8
FASTZR1
Found the Throttle Cable Clamps. Kurt White has them! Alll of them!
$10.00 each!
JohnnyB
FASTZR1
