Old 10-19-2008   #1
detch
detch's Avatar
Default no back up lights?
I just purchased a 95 and the back up lights don't work, the bulbs and fuse are good, the switch at the transmission has been replaced but still no BU lights. The formal owner had a B&M shifter installed, any ideas on what could cause this or what to do next?
thanks
detch is offline   Reply With Quote
Old 10-19-2008   #2
Default Re: no back up lights?
Hmm you sure the switch is good?
Old 10-19-2008   #3
flyin ryan
flyin ryan's Avatar
ditto
Old 10-20-2008   #4
evl_twn
evl_twn's Avatar
How hard are the switches to replace?
evl_twn is offline   Reply With Quote
Old 10-20-2008   #5
Chris_32212
sounds like there is an "open" in the circuit. that could be a break in the wire somewhere or it could be a bad switch. if you have a multimeter and know how to use it, that would be the best place to start.
Chris
Chris_32212 is offline   Reply With Quote
Old 10-20-2008   #6
Pete
Pete's Avatar
Did you make sure the little slug was still in the hole when you replaced the reverse switch.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-20-2008   #7
Jeffvette
Pete
That would be my guess.
Old 10-20-2008   #8
flyin ryan
flyin ryan's Avatar
no way to put it other than...a real B*T*H! i posted pictures a while back of an off-set 22mm wrench i carved up for the job.
Old 10-22-2008   #9
detch
detch's Avatar
what is the little slug? and where would i get one? i did not change the switch so I don't know if it was replaced.
