Old 10-14-2008   #1
Chris_32212
Default Chip info
anybody have information on which chip would be best for different applications? for example, i bought a genaric prom from exotic muscle that claimed a modest 12hp gain. but i have headers, B&B exhaust, and a light weight fly wheel. also i have heard of people programming their own chips??? is there some information on this somewhere?
Chris
Chris_32212 is offline   Reply With Quote
Old 10-15-2008   #2
PhillipsLT5
PhillipsLT5's Avatar
Default Re: Chip info
marc haibeck
Old 10-15-2008   #3
Use this link.....
http://www.zr1specialist.com/
whole lotta great stuff at Marc's site!
Old 10-15-2008   #4
Thumbs up Re: Chip info
Or Doug Rippie Motorsports http://www.dougrippie.com/
Dont forget to add the power key is always on function.
Also Xfirez51 a member here called Dom has been know to play with the chip table values a little.
Old 10-15-2008   #5
flyin ryan
flyin ryan's Avatar
i did my own for all my cars, Chris. i can help you out, if you need, but your probably better off going to Haibeck, not many better, closer to you anyways. i'm flat out building engines these days, PROM's aren't my main gig, ya know.
Old 10-15-2008   #6
Z Factor
Z Factor's Avatar
There is a lot of info in this thread regarding chips.
http://zr1netregistry.com/forum/showthread.php?t=852
Old 10-15-2008   #7
Chris
Chris,
You should start here if you are really interested in learning.
http://www.thirdgen.org/techboard/di...uide-book.html
My car went through the same "evolution" yours has. Prior to P&P earlier last winter, I had put Watson's, Fidanza and B+B exhaust so I could have a calibration that would be compatible BUT, all tuning is a compromise unless its done specifically for your car using datalogs scanned on your vehicle. The fact that you're in Utah suggests that, due to "thinner air", your motor operates in different areas of the VE and SA tables mine does.
