Old 05-24-2012   #21
RICKYRJ1
RICKYRJ1's Avatar
Default Re: C4 Chassis Stiffeners from Killebrew
I have a brand new GM X-brace that I need to install sometime soon
Old 05-25-2012   #22
scottfab
scottfab's Avatar
And I just know you'll take pictures and post'm right? =D>
Scott
Old 05-25-2012   #23
captcorvette
What I would like to know is where did you come up with a new GM cross brace? Costly?
captcorvette is offline   Reply With Quote
Old 05-25-2012   #24
RICKYRJ1
RICKYRJ1's Avatar
I picked it up last year from a member on the *************, I think I paid $150.00 shipped
Old 05-25-2012   #25
batchman
This is the first X brace I've seen. Again, thanks for posting.
+1 with gusto! Looks like something else I need to chase!
(the Killibrew setup would not be class legal for me - at least without an argument, and I would not likely win an argument at a national event)
Best,
- Jeff
Old 05-26-2012   #26
Bob Eyres
To those of you with the stock brace, it looks like it would be prone to rattling with a 3" exhaust. Is it?
The stock brace does look subject to crimping. Would it be worthwhile to box it, or build one from rectangular tubing?
Maybe boxing it would not be effective, if the brace is designed to cross tie the frame rails together rather than provide torsional rigidity.
Old 05-26-2012   #27
scottfab
scottfab's Avatar
I think two side by side 3/4 or 1in rectangle tubes that are tacked together would give better protection against crumpling. Maybe aluminum to lower the weight penalty. That and using the gimbal like Heim joints at all eight ends. This would be four way support...... that looks like this from below |X|
Scott
Old 05-26-2012   #28
VetteMed
I know that there's someone on the other forum that boxed the x brace, But I don't know that they had before/after opinions about it.
There is some contact between the brace and the y-pipe , you can see the area of rubbing in one picture above. I would like to avoid it but I haven't really noticed any vibration while driving, so it is low on my priority list.
btw, hit 198k miles today!
Old 05-27-2012   #29
scottfab
scottfab's Avatar
Whooo hoooo. This needs a "poll".
Who has the highest and lowest mileage?
Scott
Old 05-28-2012   #30
Ricky,
Have the bottom stitch welded before install. Back in 93 I had it installed stock and was not completely stisfied. Took it to Corvette Masters in Maitland, Fl, had Robbie weld plates and close it off - a world of difference.
