Old 01-22-2012   #1
RHanselman
RHanselman's Avatar
Default Best Rear Wheel Hub Assembly?
AutoZone Duralast - $77
Timken = $110
GM Dealer = $425
Any recomondations?
I have a low speed noise and vibration on number #140. I'm going to check her out today...
Cheers,
RH
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
Old 01-22-2012   #2
Default Re: Best Rear Wheel Hub Assembly?
Ron,
Doing the same thing to #458. Bought a Timken. At one point you could find private labeled NDH bearings at AZ but I don't think so any longer.
Besides, how many miles will u be putting on the car yearly?
Old 01-22-2012   #3
RHanselman
RHanselman's Avatar
This one is my daily driver until I get my Chevy Cruise back from my son... I drive around 17,712 miles to work and back for the year. 82 miles round trip...
Old 01-22-2012   #4
Pete
Pete's Avatar
See what kind of Warranty they give you with Timken.
If Lifetime i would go with Timken and you'll never have to buy another bearing.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-22-2012   #5
RHanselman
RHanselman's Avatar
Pete
3 year...
Ron Hanselman
Founding Member #80
Old 01-22-2012   #6
Coupe89
I had the same problem turned out to be bad u-joints.
1990 ZR-1 #642
Coupe89 is offline   Reply With Quote
Old 01-22-2012   #7
RHanselman
RHanselman's Avatar
I don't seem to have any play in the Hub however I do have a little lash in the right side U-Joint... Also, the tires are as hard as rocks... I'll switch some rubber around and see what happens...
Old 01-22-2012   #8
gbrtng
gbrtng's Avatar
If there is no play in the hub - top to bottom or front to rear - then the bearing is not the problem. Sounds like a tire with some cupping ...
Old 01-23-2012   #9
rhipsher
rhipsher's Avatar
Ron if you do find you need wheel hub assembly check these guys out. I bought my rear ones from them. Nos OEM. http://www.corvetterecycling.com/category_s/432.htm
Old 01-23-2012   #10
I thought of the same since I bought a set of NOS hubs for something like $120 each in 2010.
No such luck anymore - all sold out! Looks like they only have front hubs now.
