Old 08-02-2014   #1
Rumbln70SS
Rumbln70SS's Avatar
Default Trivia Question........anyone know what this Vette Doctors Black Box is?
Found this black box on my car recently and not sure what it is. I'm going to call Vette Doctors this week as I'm sure they know. The builder, Clint Hooper thinks it is to adjust the speedometer when the rear gears were changed. It appears to be spliced into the ECM wiring as well.
Any input is appreciated!
Rumbln70SS is offline   Reply With Quote
Old 08-02-2014   #2
mike100
Default Re: Trivia Question........anyone know what this Vette Doctors Black Box is?
I guess if you could ID the exact pins on the ecm it is spliced in series with, you could probably figure out what it is doing. A speedo pulse box sounds likely if you have a different gear ratio.
Old 08-02-2014   #3
Arctic91
Arctic91's Avatar
I've got one of those boxes too, so I would be interested to hear what you learn about it. Car had a lot of work done by VD and it does have 4.10s.
Arctic91 is offline   Reply With Quote
Old 08-02-2014   #4
Rumbln70SS
Rumbln70SS's Avatar
Thanks guys, I'll start tracing things down if they don't have any info. I just find it hard to believe that something this complex is to correct the speedo. I had one in my 1993 Firehawk from around 2000 and iit was so much simpler.
Old 08-02-2014   #5
USAZR1
USAZR1's Avatar
The reason I thought it might be related to the gear swap,is that 4.27's were installed. In 1998,the ratio choices were 3.92,4.09,and 4.27. The new Super 44 ring & pinions weren't available,yet.
USAZR1 is offline   Reply With Quote
Old 08-03-2014   #6
Rumbln70SS
Rumbln70SS's Avatar
I believe you are probably right Clint since you know these cars better than most. It will be interesting to hear from Vette Doctors next week.
Old 08-08-2014   #7
Rumbln70SS
Rumbln70SS's Avatar
Talked with Vette Doctors today.........drum roll please
It's for adjusting the speedo after a gear change.....I was shocked!
Clint was right and the best thing about it is they remembered the car.
Old 08-09-2014   #8
USAZR1
USAZR1's Avatar
You have a great car,Tony. Hope you enjoy it as much as you can.
Old 08-10-2014   #9
Rumbln70SS
Rumbln70SS's Avatar
I will Clint, although my daily driver has been killing us lately!
Old 08-10-2014   #10
cvette98pacecar
That is an ERA. Electronic Ratio Adapter.
