the boxes that are bolted to the bottem of the plenum. previous owner or mech must not have known they were there when they pulled off the plenum. they put them back together with black silicone . what i need is the water tight connectors that push into those boxes . help!!!!!!!!!!!!!!!!!!!!!
![]() Join Date: Aug 2006
Phrogs maybe.
#3 | |
![]() Join Date: Feb 2006
“Buy the best example of what you want, and pay whatever it takes. That way, you cry only once.†~ Bruce Meyer |
![]() Join Date: Jul 2004
Do you have apicture of what you are refering to so I can be sure of what you need?
jp
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
I dont have any way to post pics ( computor rookie) what i need is the 2connectors for the electrics that are bolted to the bottem of the plenum. guess previos owner didnt know they were there when taking off the plenum
Ok you have the ignition module bolted to the plenum then you have 2 conectors that plug into the front portion of the module they plug in.
There is a third plug that conects at the back of this module and this one has a bolt that screws into it. So you need the 2 that are at the front. I have seen these many times broken due to heat and becoming brittle.
