View Poll Results: Which coil packs do you have? | |||
AC Delco |
53 | 71.62% |
Accel |
4 | 5.41% |
MSD |
17 | 22.97% |
Voters: 74. You may not vote on this poll |
![]() Join Date: Jun 2012
Doing intel for my upcoming fuel injector change. Figure I'll change the coil packs while I'm under there so I can leave the plenum on for a while. I've found 3 types of coil packs
AC Delco p/n 10467067- $41.09ea Accel p/n 140017- $43.95 MSD Ignition 8226- $44.95 The AC delco are direct replacements I assume. My questions are these: Which type of coil packs do you have? If it's not AC Delco, what are the advantages of using another type, (if any)? ie. MSD last longer or work better. Is there any other manufacturers besides the 3 I listed? ![]() |
the ones that came with the car
![]() Join Date: Jan 2012
I pulled the plenum off after work today (someone before me broke the connector clips off almost every electrical connector - two outside the plenum and two underneath ... good grief
![]() Anyway, I purchased AC Delcos. I bought them from Amazon for about $34 each. I figure that at 22 years, it's probably cheap insurance. |
![]() ![]() Join Date: Feb 2010
Borg Warner
AC Delco. GC
MSD.
#7 | |
Well it looks like A/C Delco is the winner. I don't know if there's any added benefit by using Accel or MSD (there may be, but no one posted it), but they are more expensive. Just purchased 4 new OEM A/C Delco for 34.99 ea. from White Racing. Also purchased new Delphi injectors from FIC, and new wires and gaskets from Jerry's. I'll grab the plugs from Autozone or Pepboys. Might as well support our sponsors right.
![]() Join Date: Jul 2012
MSD. Screamin Demon also makes some
#10 |
Had an original coil go bad a couple years back, knowing I had to pull plenum I decided to put a better performance coil so I changed them all to Accels.
There's a small tab that has to be removed so they can mount next to each other, easily removed with a hacksaw blade in seconds. Didn't notice much difference than stock coil just hope they last longer...jim |
