Old 04-22-2023   #1
staminqia
staminqia's Avatar
Default Moving drivers seat forward
My wife wants to start driving my LT4 and I need to move the drivers seat forward about 1". What is the best way to do that? move the whole track forward? or move the seat mount on the track forward? Has anyone done this for their short legged wives before? LOL
thanks
Anthony
staminqia is offline   Reply With Quote
Old 04-22-2023   #2
mlipmd
Default Re: Moving drivers seat forward
? easier to put blocks on the pedals to move them closer to her feet?
mlipmd is offline   Reply With Quote
Old 04-23-2023   #3
I think I would opt for at least trying to see about moving the tracks, but I admit that I once had to put blocks on pedals. I sold my 1954 Aston Martin DB 2/4 to a lady doctor who was about 5 feet tall. She couldn't reach the pedals and said she would buy it contingent upon raising the pedal height. I sent it to my English car mechanic and he fixed her up, although I don't know exactly how he attached the blocks to the pedals. Bob
Old 04-23-2023   #4
mlipmd
They bolt right on, or through, the pedals. You can easily make something yourself out of a short length of 2x4 and glue or bolt through a covering of rubber or something to prevent foot slipping if you want to. Or paint over with a good non-skid paint. I did this in on MG TD kit car and it worked out great and was very easy to do. It was way easier to do than moving the seat track.
Old 04-26-2023   #5
staminqia
staminqia's Avatar
All fixed. I drilled four new holes in the bottom rail where the seat mounts to the studs thru the floor. She only needed about 3/4" and I made it work.
Old 04-27-2023   #6
JG95ZR1
JG95ZR1's Avatar
The seat track is already to close to the tunnel when the seat is moved All the way forward. Might have to modify the stoppers in side the tracks to get that extra inch
JG95ZR1 is offline   Reply With Quote
Old 04-28-2023   #7
staminqia
staminqia's Avatar
I like that suggestion but how do you modify the stoppers? I am interested.....
Old 04-28-2023   #8
I would not have adjusted the seats anymore forward because of the airbag. It's could be a serious safety issue for the driver. These are the 2nd and 3rd order of effects from modifying the seats.
In a race car so be it, the airbag is out of the question. However if your intention is to allow your spousal support unit to drive the car......
However, I would have looked into something like this first
https://www.amazon.com/DriFeez-Exten...46&sr=8-1&th=1
Just my thoughts. I'm sure there are better units available however, this is the direction I would have recommended.
GC
Old 04-29-2023   #9
mlipmd
You make a good point - "I would not have adjusted the seats anymore forward because of the airbag. It's could be a serious safety issue for the driver."
I don't know if an inch makes a real difference but if you are small and closer and get hit in the face with that thing, it could. That's why I suggested moving the pedals closer instead of the seat. But moving the seat forward an inch may also make it easier to reach the steering wheel if that were a problem too.
Just tell her to drive slow (Ha).
Old 04-30-2023   #10
GC
Good idea--much better than my old wooden blocks. --Bob
