Anybody have any experience with a speedometer problem and a code for the vehicle speed sensor?
![]() Join Date: Oct 2004
Code 24
Code 24 and NO speedometer? Have you done any under car maintenance recently? I'd check first the obvious. I'd check the connector at the VSS (L/R of transmission) and clean it also while there. No other codes just 24? Have you done a recent PROM or done anything at all that involved maybe ECM connectors?
Yes. We just replaced the ECM.
Yes, but the old ECM is defective. We will check the ECM and PROM connections though - thanks.
Car would run but badly - would not want to drive it that way. No indication of a prior speedometer problem, though.
