Speedometer issue - speed sensor code
Anybody have any experience with a speedometer problem and a code for the vehicle speed sensor?
Re: Speedometer issue - speed sensor code
Do you have a code that has been set? Your question is pretty vague! |
Code 24
Yes. We just replaced the ECM.
Yes, but the old ECM is defective. We will check the ECM and PROM connections though - thanks.
Car would run but badly - would not want to drive it that way. No indication of a prior speedometer problem, though.
