Old 07-12-2012   #1
TN90-ZR1
TN90-ZR1's Avatar
Default Engine Smokes
I have a 90 ZR-1 w/ 41k on the clock and an engine that's started to smoke. I figured I'd get some expert advice on exactly where to begin here on the registry. Here's the details
Smoke is blue in color
Smokes and has a strong ordor when initailly started then disapates when run about 15 mi. or so
Doe's not burn any oil ( at least from dipstick indicator )
Doe's not leak any oil
New plugs and wires less than 2k mi. ago
Any assistance would be welcome and thanks in advance.
TN90-ZR1 is offline   Reply With Quote
Old 07-12-2012   #2
Default Re: Engine Smokes
No seals on the exhaust valves.....try a 15-50 oil Mobile 1 carries it
LGAFF is online now   Reply With Quote
Old 07-12-2012   #3
if its a fuel smell and bogs, could be an injector
Old 07-12-2012   #4
scottfab
scottfab's Avatar
The only time this happened to me it was when I put in too much oil.
Oil level ok?
What do you use?
How long have you had it?
Has it been sitting?
Scott
Old 07-12-2012   #5
Pete
Pete's Avatar
1990 ZR-1's/LT5's did not have exhaust seals, they get a puff of smoke at start up no harm done,basicly normal.
If you ever do top end job i would suggest installing exhaust seals.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 07-12-2012   #6
scottfab
scottfab's Avatar
I use mostly 10w30 (6 qts) then 10w40 to top it off (2qts)
Scott
Old 07-12-2012   #7
When I went to 15-50 race oil it stopped on my 90 and 15-50 is the weight many turbo motors use to stop turbo blow by
Old 07-13-2012   #8
Jim Nolan
Plus if I recall Mobil 1 15-50 has the high ZDDP content.
Old 07-13-2012   #9
Hmmmm....
T'would be interesting to see how/why you determined that (the equiv of) 10W-32.5 is significantly different from 10W-30 - enough so anyway to go thru the bother...
P.
