Old 05-09-2010   #1
A1990
A1990's Avatar
Default Intermittent Code 63 Ideas
Hammer is traveling from the west on his trek to BG. This morning he is experiencing an intermittent code 63 on his 91.
Any ideas for him?
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Treasurer
Old 05-09-2010   #2
Bill
Bill's Avatar
Default Re: Intermittent Code 63 Ideas
Code 63 is "Right oxygen sensor not varying" . Since it is intermittent I would be looking for a loose connection/broken wire.
Bill is offline   Reply With Quote
Old 05-09-2010   #3
Dennis,
O2 sensor could be grounding also. Has he done any work in that area recently? Any chance he's coming thru Chicagoland?
Old 05-09-2010   #4
todesengel
It could also mean that the it's effective measuring range has ben reduced, a.k.a., on it's way out. I do not know a lot about the specifics on these cars, but if they are like a typical 4 wire I am used to then it coul be aything from the heater not working, or the volatge signal has become erratic. There is also the possibility, as already mentoned, that the connecton could be loose.
todesengel is offline   Reply With Quote
Old 05-09-2010   #5
A1990
A1990's Avatar
Thanks guys! He should be at my place in a couple hours. We will inspect and probably just replace.
Dennis Fierstein
Old 05-09-2010   #6
HAWAIIZR-1's Avatar
Dennis,
Tell John I said Hello too and I can wait to meet you and that awesome Atomic Z of yours..........one of my all time favorites along with Jerry's.
Old 05-09-2010   #7
GrayZ
Dennis,
Old 05-09-2010   #8
Dennis,
Just for grins, check to see if there is any moisture in the wire connector. I had one get water in the connector...... bad miss problems on that bank until into open loop. Drove it 100 miles home in 4th @ 3200+rpm. if no miss, not the problem. The short is far worse than the open.
C ya in BG
Old 05-09-2010   #9
A1990
A1990's Avatar
We will check connections first. He has reported that he hasn't had the code for a while now.
Dennis Fierstein
Old 05-10-2010   #10
Bill
Bill's Avatar
So what was it? Educate us please.
