-   -   Intermittent Code 63 Ideas (http://zr1.net/forum/showthread.php?t=11867)
A1990 05-09-2010 10:58 AM
Hammer is traveling from the west on his trek to BG. This morning he is experiencing an intermittent code 63 on his 91.
Any ideas for him?
Bill 05-09-2010 11:39 AM
Re: Intermittent Code 63 Ideas
Code 63 is "Right oxygen sensor not varying" . Since it is intermittent I would be looking for a loose connection/broken wire.
XfireZ51 05-09-2010 11:44 AM
Dennis,
O2 sensor could be grounding also. Has he done any work in that area recently? Any chance he's coming thru Chicagoland?
todesengel 05-09-2010 11:47 AM
It could also mean that the it's effective measuring range has ben reduced, a.k.a., on it's way out. I do not know a lot about the specifics on these cars, but if they are like a typical 4 wire I am used to then it coul be aything from the heater not working, or the volatge signal has become erratic. There is also the possibility, as already mentoned, that the connecton could be loose.
A1990 05-09-2010 12:15 PM
Thanks guys! He should be at my place in a couple hours. We will inspect and probably just replace.
HAWAIIZR-1 05-09-2010 12:46 PM
Dennis,
Tell John I said Hello too and I can wait to meet you and that awesome Atomic Z of yours..........one of my all time favorites along with Jerry's.
Craig:cheers:
GrayZ 05-09-2010 01:20 PM
:dontknow:
Originally Posted by HAWAIIZR-1 (Post 89416)
Dennis,
Craig:cheers:
A26B 05-09-2010 01:20 PM
Dennis,
Just for grins, check to see if there is any moisture in the wire connector. I had one get water in the connector...... bad miss problems on that bank until into open loop. Drove it 100 miles home in 4th @ 3200+rpm. if no miss, not the problem. The short is far worse than the open.
C ya in BG
A1990 05-09-2010 02:46 PM
We will check connections first. He has reported that he hasn't had the code for a while now.
Bill 05-10-2010 02:58 PM
So what was it? Educate us please.
