Old 10-24-2008   #1
Jeffvette
Default Going through DEQ Emission testing
Since I know this is a subject that comes up often. I was up for renewal and just ran my car through.
368 cube
Stage 1 cams
Stainless works headers with magnaflow cats.
Old 10-24-2008   #2
carter200
carter200's Avatar
Default Re: Going through DEq Emission testing
Congrats Now that youhave that out of the way maybe you can mail me the item you called me about
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 10-24-2008   #3
Jeffvette
LOL, calling you.....
Old 10-24-2008   #4
carter200
carter200's Avatar
Thanks for the call. I needed the laugh
Old 10-25-2008   #5
Aurora40
Aurora40's Avatar
CO+CO2 %? What do they measure that for?
Also, what the heck? Granola eating states like Washington have HC limits of 150 PPM at cruise, while "sic semper tyrannis" states like Virginia have limits of about 53 PPM?
Old 10-25-2008   #6
Hey Jeff do your headers have the A.I.R. system hooked up?
Does your state require a visual on the equipment?
Old 10-26-2008   #7
Chris_32212
i would also be very intersted to know about any visual inspections or other types of requirements for washington state as i will likely be moving back in the next couple years. not sure if i told you this jeff but i grew up just a few miles from your shop.
Chris
Chris_32212 is offline   Reply With Quote
Old 10-30-2008   #8
cuisinartvette
interesting....
VA has real strict tailpipe standards, dont know how anythign passes out there. We have tougher visuals but tailpipe is much more lax.
Old 10-30-2008   #9
Jeffvette
Chris
They do a half *** visual. They have mirrors on a wand, but it can't see under the vette. The most they will see is a floor pan.
They do a gas cap check, a idle test and a rolling 25 mph cruise. No under hood.
Old 10-30-2008   #10
cuisinartvette
Do they pressurize the tank? Just started that out here and do a "leakdown" of sorts. Guess if any assocaited rubber lines are cracked you fail.
