Old 05-02-2022   #1
spork2367
Default no spark
My parts car has been sitting. Went to start, turned over, no start. Have fuel pressure. Not ECU, not DIS. Check for spark and have none. What's next?
Old 05-03-2022   #2
Default Re: no spark
Check INJ1 Fuse.. see if it is good, has anything been done to the car since the last time it ran?
Old 05-03-2022   #3
viper107
viper107's Avatar
mice chewing on wires?
Old 05-03-2022   #4
spork2367
I didn't pull that particular fuse. I will check that tonight. No other changes. Car was started last fall.
A distinct possibility. I haven't found any evidence, but haven't ruled it out.
Old 05-03-2022   #5
spork2367
Also forgot to mention, no codes.
Old 05-03-2022   #6
And if u find that fuse did blow, the question would then be Why?
Old 05-03-2022   #7
spork2367
Fuse is good.
Old 05-03-2022   #8
JG95ZR1
JG95ZR1's Avatar
Check the connecter of the crank position sensor on the right side of the engine or do an ohm test at the connector that goes to the DIS.
JG95ZR1 is online now   Reply With Quote
Old 05-03-2022   #9
I was going to also suggest crank sensor. Without any signal, there?s no spark. Won?t set a code until ECM takes over running motor.
Old 05-03-2022   #10
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
AND the wire itself.
Perhaps it was the daily special for the the hungry local rodents.
Keep us updated.
Marty
