Old 10-18-2011   #1
Corbusa
Default I must be losing my mind :)
I just paid over $100.00 for oil... ssshheezzzz Shoot me! So ok whats the best filter ? and while I'm asking all the same old questions that been asked B4 , what type of gear oils and how much for the trans? anything special to do to change it? other than remove the drain/ fill plug and change.? OK I'm going to my corner now.......
Old 10-18-2011   #2
ittlfly
Default Re: I must be losing my mind :)
This is a new from Mark Hibeck's website as to his recommendations.
http://www.zr1specialist.com/HAT%20W...ate%202011.pdf
On the transmission oil change, be sure to remove the fill plug FIRST. If you remove the drain plug and can't get the fill plug out...then.....
ittlfly is offline   Reply With Quote
Old 10-18-2011   #3
Corbusa
Thanks That's the kind of info I'm look'in fo.
Old 10-18-2011   #4
blr33439
I just got mobile1 0/30w for about $6/qt at autozone. They have a special 5qts with a mobile1 filter for $33. They don't carry the mobile1 filter for the zr1 so you will need to buy a filter for another vehicle. I got filters for the next two oil changes on my 06tacoma. Still a great deal for what is normally $9/qt.
blr33439 is offline   Reply With Quote
Old 10-18-2011   #5
carter200
carter200's Avatar
Walmart has 0-30 for $24.50 for a 5 quart jug.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 10-18-2011   #6
Oil Filter : Bosch 3401 filter or Mobil M1-207 filter or the Fram HD filter TG3985 take your choice.
Trans oil: Castrol TWS 10w-60 buy at BMW dealership only. It's M series motor oil. Or use Amsoil MTF synthetic trans fluid at their web site. 2.2 liters capacity, so you buy 3 liters the first time.
http://www.velocitymotorcars.com/castrol.html just in case you don't have a BMW dealer near you these guys ship fast & are good to deal with.
Rear Gear: I use the Amsoil stuff, but have used the GM stuff plus 2 bottles GM additive or you can use Mobil synthetic 75w-90 fluid and it don't need the additive. I can't remember the capacity, maybe a bit more than a quart or a bit less? It's in the owner's manual maintenance section I think?
Old 10-18-2011   #7
Tom,
Marc recommended 1/2 a bottle of GM posi additive w/ Mobil 1 75W-100.
2 X 1 liter bottles were sufficient.
