I'm going to drop the exhaust to install the Hurst shifter and BB C Beam plates,what gaskets will I need at the exhaust collectors?
![]() Join Date: Jul 2005
The right side is slip on and clamped. The left side is swaged on the rear pipe to mate with the header-cat oversize taper. Behind that swaging is a 3 hole clamp and 3 bolts tighten this clamp with the threaded header-cat flange to snug the joint together. There is no gasket. Most "cat-back" aftermarket exhausts connected the same way but what you find on any particular zr-1 could vary widely.
1990 #1471 Founding #006 Former Membership Director NCM member Grand Sport registry |
#3 | |
It is 3 bolts into a threaded flange. Prep well wth penetrating oil or you might break one off. Just did mine a few days ago.
H |
The flange on the cat is threaded. (Saving a thousand words)
Not so bad... worst case you drill the bolt out, rethread to next size, buy a new bolt.
H ![]() |
![]() Join Date: Aug 2015
Wasn't a problem on my '91 when I swapped to SW headers and exhaust..
Sent from my XT1585 using ZR-1 Net Registry mobile app |
![]() Join Date: Apr 2013
When I did mine I just put a standard header collector gasket on it. Just for peace of mind...
#10 |
![]() Join Date: Feb 2012
Lately I have been dropping a lot of things; last night it was a tractor!
