Old 02-27-2017   #1
Okiedoke
Okiedoke's Avatar
Default LT5 Leak?
So I was looking around the engine bay to try to figure out how to remove the front left FX3 actuator when I saw oil. This is on the right side. The left side is dry. Anyone have thoughts on what might be the cause and how bad is this? Can I still drive it or is it benched until this gets fixed? Even if I can drive it, I assume no track days or autocross untill it's resolved?
Thanks,
Harry
1991 ZR-1 #405 (white/black with blue pin stripes)
Okiedoke is offline   Reply With Quote
Old 02-27-2017   #2
rkreigh
Default Re: LT5 Leak?
hard to see from the pics but it looks like the cam cover might be leaking just a bit. Not a big problem and ok to drive the car. Just keep an eye on the oil level and post back how much it leaks over a month or so.
I'd be comfortable driving it.
Old 02-27-2017   #3
oricale
Hello, have you had your IH off?(unit above leak)..could be IH gasket🤔
Sent from my SAMSUNG-SM-G935A using ZR-1 Net Registry mobile app
oricale is offline   Reply With Quote
Old 02-27-2017   #4
Dime
From what I've heard that's a fairly common issue and not one to worry much about. I very well could be wrong, but that's been my understanding.
Dime is offline   Reply With Quote
Old 02-27-2017   #5
oricale
Yeah, its pretty common, but with anything else could be a sign of a developing problem
Old 02-28-2017   #6
Okiedoke
Okiedoke's Avatar
I'm sorry. What is IH? Haven't done anything with the engine in years. Last time was when the dealer replaced the injectors over 3 years ago. Beyond that, it's had a recent oil change. Very odd that the oil from the leak looks so dirty...brown with black soot.
Old 02-28-2017   #7
oricale
The IH is the part with the water pipe. Also the oil could be coming from the PCV system (little rubber boot) again, not a huge deal, use a thin item with a rag around it to get all the oil you can then enjoy the car. Just keep an eye on it😉
