Old 08-05-2013   #1
Default ZF-6 part # check
I'm looking at picking up a spare Found this. Is it a correct ZF for a ZR-1?
PN: 1052000087
S6-40LT-5 540NM GM# 12455188
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 08-05-2013   #2
scottfab
scottfab's Avatar
Default Re: ZF-6 part # check
PN: 1052000087
Mine is a 90 with a (non whining) black label (my spare is also)
both have these numbers
PN: 1052000031
S6-40 GM# 10150046
Since yours in a 91 things may be different.
Scott
Old 08-05-2013   #3
Thanks, This is a Blue label 95 from what I was told.
Steve
1990 Red/Red #1473
Old 08-05-2013   #4
Jagdpanzer
Jagdpanzer's Avatar
From Bill B. web site: http://www.zfdoc.com/S640Parts.htm
1052 000 087 is the correct number for a 1995 model year transmission
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-05-2013   #5
Thanks Phil,
Everything looks good to go.
Steve
1990 Red/Red #1473
Old 08-05-2013   #6
WVZR-1
I understand the part # is correct but if I were having one shipped after a buy I'd want to see a "measuring stick" in a snapshot along side the input shaft to confirm that it's actually correct. There's a 31mm difference in the L98/LT1-4 input shaft. I'd want to see the 7.5"/190.5mm confirmed, case to tip of shaft! If it's a dimension closer to 6.279"/159.5mm it's a "no go"!
Old 08-05-2013   #7
Getting it from a ZR-1 owner in the Chicago area gtabert he is dropping it off at Marc's for me as Marc will do the install. I'm sure if its not right Mark will let me know. The #'s came from the pic. of the tags on box.
Steve
1990 Red/Red #1473
