Old 03-30-2013   #1
Default Accessory Console Wiring
I have my WB wired into the switched power from the console. Is there a fuse that protects this circuit? Can't seem to find anything in the manual. Otherwise, I may have blown my WB module.
Old 03-31-2013   #2
Default Re: Accessory Console Wiring
This is confusing
What is WB?
switched power...is that Hot In Run?
8A-11-13 shows Accessory Plug Hot In Run with 15 amp fuse in Auxiliary Fuse Block #2 (1991).
Can you just check the voltage of that circuit to see if you blew a fuse and that your ground associated with that circuit is complete to battery negative terminal?
vilant convinced me to get the 1990 and 1991 Section 8A Electrical Diagnosis Service Manual Supplement
Ebay Corvette Electrical Section 8A
Old 03-31-2013   #3
Secondary fuse block under the glove box.
Dom.in my owners manual.on page 262 there are two auxillary fuse holders. The fuse numbers are number 6 and 7 both 15 amps number 6 is the accessory plug number 7 is the cigar lighter. D
Old 03-31-2013   #4
I'll go out and check. I have that supplememental also. Is ACC plug tied in at all w cigar lighter?
UPDATE: Ok, I see its not on same circuit as lighter although same fuse block. However, diagram shows dotted line between the two legs. I had power converter connected to lighter. Spike?
Old 03-31-2013   #5
No as stated above its seperate and its a pita to get too
Old 03-31-2013   #6
This is confusing
What is WB?
Can you just check the voltage of that circuit to see if you blew a fuse?
Dom is running a wide band controller to do scanning on the fly.
Old 03-31-2013   #7
I just fly.....without the scanning
Old 03-31-2013   #8
With your ears taped back for aerodynamic efficiency no doubt Cliff. BTW how are the owls ?
Old 03-31-2013   #9
They flew away late last spring (2012)....and prolly are setting up nesting again this spring (2013) in same place.
Baby Owls just getting ready to leave the nest
Old 03-31-2013   #10
AccPlug fuse is good. Cigar lighter has power. Looks like WB interface blown. Oh well.
