-   -   Accessory Console Wiring (http://zr1.net/forum/showthread.php?t=19852)
XfireZ51 03-30-2013 09:15 PM
I have my WB wired into the switched power from the console. Is there a fuse that protects this circuit? Can't seem to find anything in the manual. Otherwise, I may have blown my WB module.
Dynomite 03-31-2013 11:22 AM
Re: Accessory Console Wiring
This is confusing :icon_scra
What is WB?
switched power...is that Hot In Run?
8A-11-13 shows Accessory Plug Hot In Run with 15 amp fuse in Auxiliary Fuse Block #2 (1991).
Can you just check the voltage of that circuit to see if you blew a fuse and that your ground associated with that circuit is complete to battery negative terminal?
vilant convinced me to get the 1990 and 1991 Section 8A Electrical Diagnosis Service Manual Supplement :handshak:
Ebay Corvette Electrical Section 8A
GOLDCYLON 03-31-2013 12:41 PM
Secondary fuse block under the glove box.
Dom.in my owners manual.on page 262 there are two auxillary fuse holders. The fuse numbers are number 6 and 7 both 15 amps number 6 is the accessory plug number 7 is the cigar lighter. D
XfireZ51 03-31-2013 12:50 PM
I'll go out and check. I have that supplememental also. Is ACC plug tied in at all w cigar lighter?
UPDATE: Ok, I see its not on same circuit as lighter although same fuse block. However, diagram shows dotted line between the two legs. I had power converter connected to lighter. Spike?
GOLDCYLON 03-31-2013 12:53 PM
No as stated above its seperate and its a pita to get too
GOLDCYLON 03-31-2013 12:57 PM
What is WB?
Can you just check the voltage of that circuit to see if you blew a fuse?
Dom is running a wide band controller to do scanning on the fly.
Dynomite 03-31-2013 01:03 PM
I just fly.....without the scanning :D
GOLDCYLON 03-31-2013 01:18 PM
With your ears taped back for aerodynamic efficiency no doubt Cliff. BTW how are the owls ?
Dynomite 03-31-2013 01:27 PM
They flew away late last spring (2012)....and prolly are setting up nesting again this spring (2013) in same place.
Baby Owls just getting ready to leave the nest
http://i287.photobucket.com/albums/l...Babes/Owls.jpg
XfireZ51 03-31-2013 01:29 PM
AccPlug fuse is good. Cigar lighter has power. Looks like WB interface blown. Oh well.
