Old 05-02-2006   #1
moesvette
moesvette's Avatar
Default Alternator going South???
My 90 seems to have the voltage charge run lower than normal after the engine compartment gets up to temperature. It runs about midway on the gauge, which looks to me like about 12 volts. When the engine is cold, and I first start up, it seems to run closer to 16 volts for awhile. When the gauge reads lower, the blinkers work slowly (especially at night with headlights). Does this mean I am looking at an alternator change soon?
Thanks!
1990 Red/Tan Mark Haibeck Chip/B & B
moesvette is offline   Reply With Quote
Old 05-02-2006   #2
Default Re: Alternator going South???
I would say it could be the alternator but I would have the charging system tested. This way the alternator, starter & battery get checked. It could be that the battery is having issues also or even if the grounds are loose or maybe dirty.
I would do the system analyzer first. JMHO.
Old 05-02-2006   #3
carter200
carter200's Avatar
I agree with Tom on this. Autozone does the checks for free in most places. Good luck
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 05-02-2006   #4
moesvette
moesvette's Avatar
Thanks guys. Good idea. I did change batteries about 2 months ago. Maybe my ground is not anchored well. Will check that and have a system check done and see where that takes me.
