Old 02-24-2012   #1
Blue Flame Restorations
Default Wheel spacers
The convertible Project is about to begin.
I need to find a supplier for wheel spacers, not adapters. Is the correct word "concentric"? I will need at least .500 (1/2") spacers, maybe more? I have purchased long wheel studs already.
The rear wheels are 13" Dymag GenII's and fronts are 11".
Also need a set of C5 calipers, if anyone has a nice set for sale at a good price.
Thanks
Brett
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 02-24-2012   #2
VetteMed
Default Re: Wheel spacers
Concentric would be describing 2 circles with the same center. Hubcentric is a wheel or spacer that is centered by fitting on the hub. Lugcentric is centered by the torque of the lugnuts. I think.
Old 02-24-2012   #3
Well I learned something today
Old 02-24-2012   #4
Me too. I think I need hubcentric then. I just want the spacer not to move.
Old 02-24-2012   #5
gbrtng
gbrtng's Avatar
I have two that are 0.75" thick - fastened to the hub with wheel nuts and have studs for the wheels. Interested? I can probably round up 2 more if you need a full set.
Old 02-24-2012   #6
I have two that are 0.75" thick - fastened to the hub with wheel nuts and have studs for the wheels. Interested? I can probably round up 2 more if you need a full set.[/QUOTE]
Thanks for the offer. I think I just want a spacer though.
Old 02-24-2012   #7
carter200
carter200's Avatar
I can do that. PM me.......
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 02-24-2012   #8
Thanks, Carter!
Old 02-24-2012   #9
Mine are both hub and wheel centric spacers. 18mm and I use GM racing studs for the rears.
Old 02-24-2012   #10
These 13" Dymags will be my determining factor, I think?? I emailed Daniel to see what spacers he has, if any. The rotor hat depth will be a factor too. running stock rotors until the car gets painted, then something more performance oriented.
The special offset makes the need for a sway bar monuting that sucks the sway bar inward OR Dieline made a narrower sway bar. My wheels want to rub on the stock sway bar mounting bracket. I have about 1/8" clearance. Too close!!
Daniel's white Dieline Baker car setup.
