Old 12-12-2013   #1
Z06scentair
Z06scentair's Avatar
Default What size allen wrench for the diff drain plug?
I searched and didn't find what size allen wrench to remove the fill plug on the differential?
Any help.
Old 12-12-2013   #2
92whiteZ
Default Re: What size allen wrench for the diff drain plug?
I believe its a 10 mm
92whiteZ is offline   Reply With Quote
Old 12-12-2013   #3
Z06scentair
10mm seems to small from looking at it.....headed to harbor freight in the morning. I will buy a big set and hopefully hit the jackpot.
Thanks for the chime in!
Old 12-12-2013   #4
Is it 10 mm 3/8"
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 12-12-2013   #5
Default size allen wrench for the diff fill plug?
Originally Posted by We Gone View Post
Is it 10 mm or 3/8"
3/8" which is 9.525 mm for Differential Fill Plug.
See Item 5 for the addition of the Differential Drain Plug LT5/ZR-1 Fluids
Old 12-12-2013   #6
3/8" which is 9.5 mm
I was waiting for you to post up the correct answer
Steve
1990 Red/Red #1473
Old 12-13-2013   #7
Z06scentair
Thanks guys headed to the harbor freight toy store!
Old 12-13-2013   #8
Default Harbor Freight
When you are at Harbor Freight....get one of these
Hydraulic Aluminum Floor Jack (3 ton)
a. Pittsburgh Racing
b. Very low initial height and weighs 55 lbs.
c. High lift rate.
d. Minimum Saddle Height 3-3/4 inch.
e. Maximum Saddle Height 19-1/4 inch.
3 ton Pittsburgh Racing Aluminum Floor Jack
ZR-1 and LT5 Tools
Some More Stuff you can get at Harbor Freight
Lifting The LT5
Lifting and Towing the ZR-1
Old 12-14-2013   #9
Z06scentair
Default Re: Harbor Freight
c. High lift rate.
ZR-1 and LT5 Tools
Lifting The LT5
Luckily I have a couple of lifts so no need for a jack.....got a set of allen wrenches yesterday at the china freight store. I may try and tackle it today!
Thanks to all!
Old 12-14-2013   #10
Racinfan83
c. High lift rate.
ZR-1 and LT5 Tools
Lifting The LT5
I got one of the next model down from that last week for like $69... Whole lot easier to use then my heavy 3 ton steel floor jack...
