Old 3 Days Ago   #1
petervankleeck
Default Vacuum line replacement
Gentlemen,
Where do you find vacuum line and rubber couplers for the 90ZR1? I have a couple of broken lines that need to be replaced. Thanks in advance.
Peter
90 #659
petervankleeck is offline   Reply With Quote
Old 3 Days Ago   #2
beermanpete
Default Re: Vacuum line replacement
Jerry's Gaskets has all of the special molded parts youvwill need. I just replaced all of the vacuum hoses on my '90 and replaced the fuel injectors as well. Jerry's has all the parts.
https://jerrysgaskets.com/
beermanpete is offline   Reply With Quote
Old 3 Days Ago   #3
petervankleeck
Thanks!
I was just on Jerry's and ordered some gaskets. The reason I posted this is because I couldn't find the vacuum lines. I guess I just missed it. I'll go back and look. Thanks!
Old 3 Days Ago   #4
All Vacuum Hoses?
I replaced all secondary port throttle lines/connectors several years ago and did not know that those lines/connectors were available now???
Post 284 - New Secondary Port Throttle Vacuum System
Old 3 Days Ago   #5
beermanpete
No, not the secondary hoses, so not all hoses. I had the PCV hoses and other molded hoses replaced because they were soft and leaking which was causing problems.
Old 2 Days Ago   #6
petervankleeck
Originally Posted by petervankleeck View Post
Gentlemen,
Peter
90 #659
Any ideas or do I just do a work around? Thanks!
