-   -   Vacuum line replacement (http://zr1.net/forum/showthread.php?t=35818)
petervankleeck 03-26-2025 01:52 PM
Gentlemen,
Where do you find vacuum line and rubber couplers for the 90ZR1? I have a couple of broken lines that need to be replaced. Thanks in advance.
Peter
90 #659
beermanpete 03-26-2025 03:53 PM
Re: Vacuum line replacement
Jerry's Gaskets has all of the special molded parts youvwill need. I just replaced all of the vacuum hoses on my '90 and replaced the fuel injectors as well. Jerry's has all the parts.
https://jerrysgaskets.com/
petervankleeck 03-26-2025 04:57 PM
Thanks!
I was just on Jerry's and ordered some gaskets. The reason I posted this is because I couldn't find the vacuum lines. I guess I just missed it. I'll go back and look. Thanks!
Dynomite 03-26-2025 08:28 PM
All Vacuum Hoses?
I replaced all secondary port throttle lines/connectors several years ago and did not know that those lines/connectors were available now???
Post 284 - New Secondary Port Throttle Vacuum System
beermanpete 03-27-2025 12:30 AM
No, not the secondary hoses, so not all hoses. I had the PCV hoses and other molded hoses replaced because they were soft and leaking which was causing problems.
petervankleeck 03-27-2025 04:04 PM
Originally Posted by petervankleeck (Post 347920)
Gentlemen,
Peter
90 #659
Any ideas or do I just do a work around? Thanks!
