Re: Did you eliminate your Secondary Throttle Vacuum System?
Anyone notice lower fuel mileage after removing the secondaries?
I assume all 16 injectors will run all the time versus 8 under normal driving conditions. |
Hard to tell, my foots always in it. I guess from that perspective mileage is worse because you want to floor it all the time.
H :cheers: |
That make sense, thanks for the info. |
@ 70 mph in cruise I got 26.4 mpg (as I recall). That was almost identical to what I got before deleting the secondaries.
I didn't notice any difference in MPG with them removed
